Trans fluid leak?
Trans fluid leak?
Hello can someone guide me as to what this leak could be? Trans fluid? I thought I was leaking oil from the oil pan but I don’t think this is that.
If i were to guess i would say trans pan gasket. BUT It also looks wet in front of the pan so it may be a front shaft seal. Tranny would need to come out for the front main seal to be replaced. Normally gravity pulls fluid down so start by looking where the fluid starts getting the transmission wet even though it's wet on the pan it might be coming from further front of the car and getting blown back by the wind as you're driving. You can also clean it up and wait for it to leak a little bit more and it'll be easier to tell where it starts.
Aathon H.
Aathon H.
Gustavo621 (04-03-20)
https://www.ssl-parts.com/?gclid=EAI...yAAEgJOFfD_BwE.
You could always call the dealer and get the part# from them. Once you have the part#, you can then check with Toyota as well. Same PN# is shared sometimes for common hardware between the brands.
Check the link below. Usually they show the diagram as well so you can probably get the part number for the bolt from it.
thank you so much for your help !! Greatly appreciated!
