Lexus IS350 - transmission, wrong TC can I put a different TC in transmission
Image says it all, if I’m missing anything please feel free to comment. I’m wondering if I can use the torque converter from my last transmission, into the transmission which I bought. Problem was, as the bought transmission was put into the car - the mechanic working on it told me the car felt “stuck” when attempting to start it. So he took everything apart again (headers, exhaust etc..) to take the transmission out and he learned I was given a faulty TC.
he informed me that the torque converter since it was the wrong one, actually wouldn’t align properly - initially he thought the transmission wasn’t aligned in properly but after taking everything apart he said it was the TC mismatch that is causing misalignment . Maybe it however could be something else, will update when original TC is placed into the transmission !
I dont know much about Transmissions but i did relpace my own on my 06 is 250 rwd and did quite a bit of research. Rwd tranny has some different characteristics than the awd. If u bought the RIGHT tranny it should have the right tc with it. If its not starting it may be the wrong tranny i would assume. Ir something wasnt put together right. Rwd tranny is a a960e from 06 to 2014 will all work. AWD is a760h. This same tranny was put into 2013 and newer Subaru brz and scion frs 2014 and newer but also have different characteristics like bell houseing and output shaft exc. Make sure u or whoever got the tranny got the correct one.
Unfortunately the mechanic most likely screwed up the install. How you ask, the TC has like four different sets of splines that must engage when installing the TC into the trans. A transmission once shipped or tipped forward will allow the TC to slip out and disengage 1 or more sets of splines.
If installed this way and the bell housing bolts tightened, it damages the front pump and TC while locking the TC in place just as you described.
A costly mistake that many newbs make. I'd guess the only way you prove it is by having an actual transmission mechanic tear it down and show both of you the damage.
You might open the conversation by asking the installer how they verified the TC was fully seated before installing into the vehicle?
Mind you, during the install, all you have to do is tip the nose of the trans down a small amount and the converter slips out. If not caught, damage occurs when the bell housing bolts are tightened.
I used to R&R and build autos, manuals, transfer cases and all of that for AAMCO so not my first rodeo...
IS250DIYER (04-13-20)
Aathon H.
leg3ndary
10-18-17 12:41 PM
