Door lock
Door lock
Hello guys I have a 2011 IS350 most of the time when I press unlock on the remote and the door only driver door open I change the Actuator on the front passenger door but same time happening any help please
With the key fob in your pocket, does the same thing happen when you touch the driver's or passenger's side door handle? I believe it is standard that the driver's side only unlocks when that handle is touched, and all four doors when the passenger handle is touched.
Try to hold the unlock and lock button down on the remote at the same time for several seconds until it beeps.
You can have your Lexus Personalized Settings changed so that when you push the button on the fob one time, all 4 doors unlock. That setting must be done using Techstream or by the dealer.
Thanks once you touch the door the driver door open when you get in and press the unlock on the door nothing happen if you press unlock on the remote nothing happen also
The 1 door / all doors works via the remote and/or touching the passenger door strip w key in hand.
As said above, this is done by pressing and holding lock+unlock until it beeps a lot.
Does yours beep? It sounds like the actuator failed. Please advise; do the back doors unlock from the all unlock on the drivers door?
Another member w a convertible said the button hold technique (remote in range of car) did not work on their C model.
Yes it’s a base model, when I press unlock from the remote or from driver door only the driver door unlock if I manually unlocked all the other doors by hand then press lock they all will lock then when I press unlock again same thing again only the driver door unlock
