Check VSC, CEL, and traction light
Hi all. I have an 06' IS350. Recently I have been noticing the CEL, traction, and Check VSC light turning on and off. Some days it'll be on for 1-3 days, and others it'll be off for a whole week. This has been going on for half a year now. I replaced the sensor but that did nothing.
Please advise, thanks!
Corrosion was evident on the sensor. I did have the engine swapped (65k) a few weeks ago. As soon as i got the engine swapped, I had the sensor replaced too. About two weeks after this, I started getting the VSC and CEL lights on again. I also have an RR-Racing tune on the car. I'm not sure if that helps with diagnosing the problem.
With the original engine and old sensor, I had this code. After swapping the engine and replacing the sensor, the code went away for about 2 weeks. Now it's just coming on and off every few days. I'll try setting back to stock but i know of many people with the RR tune that haven't really had this problem. So i was speculating that it had something to do with the air-fuel ratio sensor.
