Diag VSC Message
Diag VSC Message
Hey guys, last night the VSC light came on and I also got a diag vsc message on the display.
This morning i plugged in my bluetooth OBDII and got on the fusion app. But it didnt show that i had any codes. This is my first time using any OBDII scanners so maybe I'm not looking in the right places to get the code since Im a newbie at this. Or can you guys be able to tell me what the problem could possibly be? fyi I just had my exhaust installed this weekend. tanabe+invidia midpipe. Maybe that he has something to do with it? I dont know. I tried disconnecting the negative terminal for 20 minutes to see if itll reset itself but didn’t do anything.
Since Fusion doesn't have ABS capability. Do you have the Lexus/Toyota add on package? If so there should be a PID maybe for wheel speed. By using that you could see if all 4 wheels are giving out a signal for the speed sensors.
Just curious it could be a dead wheel sensor. My car is AWD so I see 4 Wheel Drive under the add on package. I'm able to see each wheel MPH.
Yeah luckily I stored that ECU with all other stock parts i removed. And yeah I had no issues/warning lights before this. Its been since like January or February when I first installed it.
I saw a couple of videos on it. I think I know how to do it. Now the hardest part, i have to find a paper clip haha
https://www.clublexus.com/forums/is-...t-on-help.html
davidbusta (05-14-20)
This is what I came up with POST #10. Count the pins from left to right. Ensuring the paper clip is in the correct locations. You'll have to be on your back looking up, and preferably a flash light to view the DLC plug.
