Not displayin on screen
I have a 2009 IS250. I have got problems 2 days ago about displaying my screen. My radio is working, CDs
Radio, Time, volume works, but not displaying. thats why we cant conrol the ac, map, etc
payer working. but not displaying.Cant control ac, map,etc.. any ideas?
The digitizer on the screen often goes bad. Most likely cause. There’s some articles here on how to repair. Hit the search bar and enter : lexus is350 digitizer.
If you're a lucky man its the digitizer
if your like me, unlucky, then it is the motherboard and you need a new unit. I saw no point in buying a used unit so I went aftermarket 600CAD
Super Moderator
I'm pretty sure that a replacement digitizer won't help. The new digitizer is used to repair a unit when the screen no longer responds to touch, not one that has no display.
JohnBrown7, check #4 fuse (10 amp),in fuse box located under driver side kick panel (IS 350). I pulled fuse to troubleshoot, and display remained dark. Re-installed fuse and display returned. Confirm fuse is good.
Cam across the following thread discussion about defective OEM digitizer displays;
https://www.clublexus.com/forums/is-...ix-diy-31.html
Member RPMGraphic provided the following about black / blank screen; "-In my research it seems as the blank/black screen issue is caused by the fan on the main PCB going out & the board frys". May be what you may be experiencing if not the fuse.
O1GS43O
02-10-11 01:46 PM
