Need help with wheels
I just purchased a 2010 Lexus IS250 and its my first time really buying anything for a car so I just have a question it might be stupid.
Im looking to buy some Option Lab R716 Gotham Black 18x9.5 +35 5x114.3 but I know that the bore for my car is 60.1 while the Option Lab wheels bore is 73.1. I've seen others running this wheel on their IS so im just wondering what specifically do I need to do or buy for it to fit my car?
You will need 4 hub centering rings 73.1 to 60.1. Make sure you clean the hubs with wire brush and apply little bit of anti-seize grease on them. Metal or aluminum made rings will last you longer then the plastic ones.
Rennz—-If youre buying the wheels new any reputable vendor will be aware of the center rings you need,include them in the price and most of the time will also include the corresponding lug nuts . Simple to install center. Rings—they just slip into the center bore from the back/inside of the wheel. Good luck——LJ
primavera (06-11-20)
