Had both rear axles replaced now differential is leaking
Drug the splines through the seal (new or used).
Didn't lube the seal with grease (new or used).
Knocked the tensioning spring off (new or used).
New axle has grove, a bur, a dent in sealing surface. Unlikely if a reman, but possible if mishandled.
Didn't replace the seals while there.
Didn't seat the axle fully.
Those come to mind.
Those come to mind.
