My thoughts on installing an ISF Steering ECU
#76
Side note, I heard back from a local Lexus dealership (still waiting for Toyota's response):
Hello,
Thank you for your inquiry with us, I have attached our Shop Foreman to this email who will be best suited to answer your questions. If this is possible to perform the cost will be $159.00-$238.00 + 13% HST.
Have a great day!
Assistant Service Manager
Have a great day!
Good morning,
As you might already be aware, the power steering ECU and steering gear assembly work in conjunction with each other. This is indeed an unusual request and it might simply not work. As long as you are aware that we are willing to try and initialize the torque and angle sensors for you, providing you sign off on liability and warranty issues that might arise from the work. We will try to accommodate your request and let you know if the computer allows for the combination or not. Hope this helps.
Regards,
Shop Foreman
Regards,
Shop Foreman
Now, the shop foreman's warning about the different components working together brings me to a question - am I right in assuming this ECU would cause higher wear/tear to the mechanical components over time compared to the OE ECU? So far I've only come across people sharing their positive initial feedback, but no one has shared any failures/maintenance issues that arose (besides power steering not available immediately after the install due to calibration not being done yet), so just wanted to get peoples' thoughts.
#77
OG Member
#78
That's bold haha! But based on all the positive feedback I've come across on the site, I doubt anyone would take you up on that
This is lower than I expected to be honest and I'm assuming Toyota will be even lower, so I'm going to try a new unit ending -41, @AMIRZA786, but thank you again for your offer!
#79
#81
Ps, I literally just last night subscribed to your YT channel, great content!
Just let the shop manager know that there are a large number of 2nd Gen IS owners that had this installed for years. Also let them know that those that bought used ones didn't have to have them re-calibrated. It's kind of like this: buying and installing LCA bushings for an RC-F on an IS350. They fit the car perfectly, and improve the cars handling and stability substantially, yet when you buy them from a Lexus dealer or an online Lexus parts store, you get a message that's it's not compatible and doesn't fit. On top of that, the Lexus dealership will probably not want to install them, although they actually improve the cars performance
Fwiw, my local Toyota just got back to me to say they won't do it... so the Lexus dealership it is!
redspencer (09-16-20)
#82
Keeping it Real
The IS250 RWD, IS350 RWD, and IS F all use the same steering components, including the rack and column. The only difference is the programming in the EPS ECU.
If there were to be increased wear to the components, it would already be happening to IS F's.
But, they like to cover their bases.
Any Toyota/Lexus dealer or anyone with a Techstream can do the EPS calibration. If one dealer won't do it, call another. Don't even need to tell them what you replaced it with or why, just say you replaced the EPS ECU and need to have it calibrated, what would they charge to do that and see what they say.
Jeff
Jeff
The following 4 users liked this post by Jeff Lange:
#83
Wow this sounds like a great improvement. I can't stand the spot that is twitchy but also dead at the same time, on straight line highway driving that many Toyotas have. Very weird to me. Glad this fixes that.
AMIRZA786 (09-16-20)
The following 3 users liked this post by 2013FSport:
#85
Haha they know. There is only a limited amount of 2011 ISF's on the road, and the most sought after EPS is for the 2011 ISF. I was talking to a Lexus Parts manager looking to see if they had an upgraded part specifically for an F-Sport accessory, than I asked him if the same RC-F part would work on my car. He told me to check on clublexus LOL "cause these guys have tried everything". I almost burst out laughing
2013FSport (09-17-20)
#87
@AMIRZA786 You might want to add the ISF steering damper to go with the ECU. It makes a difference.
#89
Jeff
Jeff
It's interesting how different dealers have different policies. The first Lexus dealer agrees to it if I release them from all liability; the second one said they won't calibrate unless the part is provided and installed by them, which doesn't make sense but I didn't argue. The First Toyota dealer said pretty much the only Techstream related work they can do on a Lexus is TPMS programming and suggested I ask a Lexus dealer, which again didn't make sense; now waiting to hear from the second Toyota dealer who has been my primary source of parts so far.
Thanks also for the note on the same components, Jeff, good to know!
Also, sorry for hijacking your thread dude!
