DTC Codes help
Hello, 2005 IS250 has some codes need explaining, please help:
Fault code: DTC0P2127 Throttle/Pedal Position Sensor/Switch E Circuit Low Input (I have a Throttle controller that jacks itself between the foot pedal connection, this might be it)
Fault code: DTC0C1223 ABS Control System Malfunction / ABS Malfunction
Fault code: DTC0C1241 Low Battery Positive Voltage or Abnormally High Battery Positive Voltage / Low battery voltage
Fault code: DTC0C1249 Open Circuit in Stop Light Switch Circuit / Open circuit in stop lamp switch circuit
(Will replacing the ABS Module solve the problem?)
Fault code: DTC0U0121 Lost Communication With Anti-Lock Brake System (ABS) Control Module (Sounds like ABS ECU need replacing?)
