Lexus is 250 high idle
Lexus is 250 idles high even after cleaning throttle body and maf
it takes too long to heat up around 20 mints even after 20 mints rpm stays 1000
any solution
any solution
What’s your temperature outside? This car idles over 1k rpm when weather is cold.
cleaning throttle body could also make it idles high for a while, but it should come down within couple days depends on how much you drive.
I noticed even if car is at operating temperature after a drive i shift it to neutral it idle good at 700rpm but after 10 seconds it goes back to 1000rpm
