Custom rims question
Will rims with following measurements fit my 2006 is350 with stock suspension and is so what size tires should I put on them for optimum fit.. Size: Front:18x9, Rear:18x10
Offset(ET): Front:+24mm, Rear:+22mm
PCD(Lug Pattern): 5x114.3mm
Hub Bore: 70.6mm
thanks in advance for input on this...
Hub Bore: 70.6mm
This is response I got from the dealer of the rims. FYI.
These will bolt up, however, the offset is too low for your car. These will be about 2 inches further out from stock. Unless you cambered them in for the stance look.Regards
Customer Service
Customer Service
Those offsets/ widths look a little too aggressive unless you are gonna camber the hell out of them with super starched tires.
I have 18x8.5 fronts with +35 offset and 18x9.5 rears with +40 offset and they sit pretty flush with the fenders.
Clean ride dude... did you have stock suspension or it it lowered with springs or coilovers?
If I go 18x9.5 35mm offset all the way around will that be to extreme?
LilMan23
09-04-09 01:57 PM
