My AC cooking fan broke........
And I can see by looking at the hub of a fan that left that the broken fan got jammed into the hub/motor and the result is neither fan works ac on or off they don't work, now I've checked the fuses and relays all are fine, maybe a fusible link or did I fry something, I can't go anywhere in fear it'll overheat, it's 90 degrees outside today, someone reach out and help a Lexus brutha out.
Last edited by jester8609; 10-07-20 at 04:57 PM. Reason: Problem solved, thanks for the help
Too much decoding required. Sounds like someone dropped a pipe wrench in the fan, s h ¡ t broke, and now neither fan does the spinny thing. Sound about right?
What were the names of the fuses checked? How were they verified? If the fan is missing a blade or damaged, better just replace it.
