ISF Sway bar bushings
I want to verify if the Sway bar bushings for a 2008-2013 ISF will work with the F-Sport Sway bars installed on my 2010 IS350 RWD. Here are the part numbers:
48815-53060- Front sway bar bushings
48818-30180- Rear sway bar bushings
According the Lexus Compatibility chart, they fit 2008-2010 ISF as well as 2013-2015 IS250/350 F-Sport models
The IS F front bushings are almost the same size as the F-Sport accessory front bar, but slightly larger. They cannot be used with the factory ISx50 bar, sport suspension or otherwise.
The IS F rear bushings are the same as the 2009-2013 ISx50 Sedan with Sport Suspension (including factory F-Sport models) and the 2013-2015 IS C F-Sport, they cannot be used with the non-sport suspension bar or the F-Sport accessory bar.
Jeff
Jeff
AMIRZA786 (10-28-20)
Jeff
Jeff
For the rear stock ISF bushings remember they are 17mm ID, and the F-Sport bar is now 19mm ID. So they won't work.
IS-F front sway bar bushings.
![](https://cimg6.ibsrv.net/gimg/www.clublexus.com-vbulletin/1000x554/51_chaogfrl_ac_sl1000__655ca8646ac4a5fe8a4991791b0d519048c09ce7.jpg)
A little bit of noise when going over bumps (squeaking) which started a few weeks back. Ever so slight rattle coming from the front sway bar when going over bumps/driveway. Nothing horrible. Next year I'm planning to install F-Sport suspension, so I wanted to maybe change the sway bar bushings to better ones. Driving my old Camry over the weekend made me realize how quiet a car can be!
I'm using the IS-F bushing on my F-sport front sway bar. The F-sport front bushing are trash and I replaced them within a month of use with IS-F ones with great results, no noise so far.
The following 2 users liked this post by Yamehoo:
AMIRZA786 (10-28-20),
Jeff Lange (10-29-20)
So the ISF front sway bar bushings do fit the F-Sport sway bar? You didn't have to modify anything?
AMIRZA786 (10-29-20),
RJMacReady (07-07-24)
I might try that, but I was under the impression that rubber bushings don't need to be greased. The stock sway bar bushings were untouched for 10 years and never squeaked, but the stock sway bar is also thinner and lighter. Anyway, if the ISF front sway bar bushings fit, I may also go that route, they are about $38 at my local Lexus dealer. I can honestly say that meeting @Yamehoo and seeing how he works gives me confidence
The F-Sport bushings that came with mine, plus the replacement ones I bought last month are 100 percent rubber
I ran the IS F bushings on my front F-Sport bar for a bit after having replaced the F-Sport bushings once or twice. They were better, but eventually I just changed out the bar for an IS F bar, which I actually find to be a better balance (IS F front bar, F-Sport rear bar). Is it faster on the track? Not sure, but I like the way it feels. From memory all of my F-Sport bushings were rubber as well - perhaps they updated them? This was many years ago for me now.
The IS F bushings fit with the F-Sport front bar without any issues, though as I said originally, the F-Sport bar is slightly thinner, so they're not quite as tight as they are on the IS F bar.
Jeff
Jeff
