Sway Bars for 250 AWD
Just got my stock IS250 AWD. Looking to add front and rear sway bars. Which ones are recommended? I know people like the F Sport ones but I believe that's only for RWD. Ty
F-Sport. Bell Lexus is usually the cheapest to buy the set from, here's a listing for the front, and rear sway bars for your AWD model: https://www.ebay.com/itm/LEXUS-OEM-F...75.c1#viTabs_0
Mattstermh (12-02-20)
F-Sport Sway bars. I would also order front ISF sway bar bushings part number 48815-53060, as the ones that come with the F-Sport sway bars are polyurethane and will eventually squeak and rattle
EDIT: Not sure if the ISF front sway bar bushings will work with AWD models. If someone can verify if they do or not. If not, make sure you grease the F-Sport bushings or they will squeak in a month
