Is250 2012 code P0103 & P0113
I have a reading code P0103 & P0113 after installed my new sensor. I could installed wrong wires, could anyone verify if I install the wires to sensor is corrected.
MAF sensor part # 22204-31020
Sensor Pin 1 ---> THA (5V)
sensor Pin 2 ---> E2
Sensor Pin 3 ---> B+ (12V)
Sensor Pin 4 ---> E2G
Sensor Pin 5 ---> VG
Someone access to my car and stole the parts and cut off the wires where connector connect to Maf sensor. I was wired base on schematic, but I not sure if this is correct or not. The code reading the same whether there is no Maf or not. I think the power pis input for mass sensor is not pin 3 but could be pin 1.
I spliced the wires with the standard wire connectors, not soldering/ butt connectors. I will soldering when there is no code reading. The car is run with a trac on, but when I clear the code is back to normal.
Welcome to CL
GX - 2nd Gen (2010-2023)
1685
07-10-24 12:09 PM
Dan040286
ES - 5th Gen (2007-2012)
08-17-19 03:32 PM
Rbeeber
12-02-18 08:42 PM
