No crank no start/dead key fob
My IS350 will not start after battery in the key fob went dead. I was holding the fob by the ignition button to start it for a couple days. But now it's not working. I checked the battery.. The battery is fully charged. I have not tested the alt nor have I tested the starter. Please help. It seems it would be something simpler. When I turn the key on all of the dash lights light up but as soon as I push the brake to start it half my dash lights go off and so does the fan that is wired directly to the fuse box. Any suggestions? I replaced the battery on the key fob n nothing.
Reassemble connecting the Positive terminal first (and tighten it), then the negative. Try starting the vehicle. If this doesn't help, try jumping it with another vehicle.
When making the Negative ground connection, connect the jumper cable to the engine block on a clean unpainted surface. Try starting again.
Please keep in mind that the cable terminals to the the battery should not move by hand when grabbed and twisted.
Keep us posted....
Dly200t
12-29-20 08:04 PM
Livento
12-22-19 02:37 PM
