IS350 Evans
Just got an 07 is350 and i usually convert my cars to evans coolant and i want to do it to my 350, does anyone know of any problems or negative consequences as a result of doing so.
Thanks
Thanks
We use Evans a lot in BMWs since their cooling systems are plastic garbage, the theory is that w/o any pressure in the system from the Evans liquid... you'll be putting less strain on it, so less chances for cracks.
Assuming you do remove ALL water from the system (pretty much even a little will result in Evans getting pressurized and defeating the purpose), I've never heard of any negatives to it.
That said, not sure how needed it would be in the a Lexus.
Personally I would stick with Toyota pink. 100k miles change interval, never had a cooling issue on my harshest drives in either 115 F through steep inclines and long trips with the AC on, or subzero temps
Since 1995 I've owned 7 Toyotas (one of them reached over 200K) all with ZERO heating issues over the cars lifetimes. I've driven them on many long trips in harsh conditions and high temps at high speeds, including hundreds of trips between Northern and Southern California (an average of 360 miles each way) in all types of weather conditions, including high temps in SoCal traffic. If the car was well maintained than the OEM coolant is totally sufficient. $49 a gallon seems pretty steep, especially for a car with a well designed cooling system as Toyota/Lexus's. But if it gives you piece of mind, I don't think Evans will hurt anything
