OKNavi Android Headunit Issues
Hi
I just received and installed my new head unit that I bought from Aliexpress at OKNavi Store. I installed it and everything seems fine except:
-Controls on the steering wheel only work the volumes and when you press it nothing happens on screen but you can hear slowly the volume decreasing. Skip track doesn't work.
-A/C only work on the physical buttons on the headunit and again it does not show anything on screen when you press it and the A/C app doesn't work at all
-Door open doesn't work
-Rear speakers don't work
Has anyone had this issue? I configured the CANBUS to Lexus and then IS L and IS H and none of them work.
My head unit is an android Octacore, 64gb rom, 4gb ram, DSP
I saw another post on this forum where someone had the exact same issues as you, and as I remember the solution was vendor sent them another CANBUS which fixed the issues
Lexus IS 250 2008 upgrade
Hi Hello First Time Here,
Lexus is 250 2008
Replace radio for a Tesla Radio
install new Skar 1500 watts
install New 2. 12 inch subwoofer 750 watts
install Rocksfor Fosgate 4/ Channel Amp 550 Watts
support The Pionner car Amplifier
replace inside woofers and Twitter 160 Watts each
install New Battery Lithium’s TItan 8 5000 watts
keep equipment works for 8 hours
install new Cat-back exhaust
install new KG intake
Skar 1500 Amp for Subwofer
Olmos finish the set up
From Battery to New Battery Lithium to keep power
New set up for Power the Amps
Lexus is 250 2008
Hi VapeDude
Did you get these issues sorted out?
I also bought an aftermarket android headunit (https://www.aliexpress.com/snapshot/...35395421149525).
And I also got the exact same issues as you aside from the door open light as I haven't tested this one yet. But how were you able to get into the CANbus configuration settings?
Any help would be much appreciated.
Hi VapeDude
Welcome to CL
08-10-24 06:19 PM
