06 is350 headlight bulb replacements
I have my drl lights turning off as well as the headlights during night time driving. I believe the high beams still work. I want to replace the drl lights and the headlight bulb for the oem headlight assembly, and I was looking for some part #s or the oem bulbs.
I have the afs feature where the bulbs move to the right or left I think, and its a blue light when using low beams, and the drl light is yellow.
Does anyone have recommendations for the oem bulbs this uses? I have seen utube videos showing philips brand but not 100% sure about that.
Brand doesn't typically matter, most of the OEMs are the same in quality. It's the aftermarket ones you may need to be wary about. I'd stick with buying from TheRetrofitSource/XenonDepot. If you want the OEM color, it should be 4300-4350k. Osram/Sylvania, Philips, Toshiba, etc. I personally have a set of Osram CBI 5000k bulbs in my car. Just make sure you buy D4S and not D2S, D2S will not work with the ballasts.
As for the high beams/drls, it's a 9005 bulb. You can just grab any bulb from your local Walmart/Walmart equivalent. Most stores will sell Sylvania bulbs. I want to say I have Silverstar Ultras in mine. I have my DRLs disabled to prolong bulb life.
Raven01750
04-24-21 04:52 AM
