Pulling out steering wheel
To remove the steering wheel on the IS250, i understand you have to loosen the nut a little then pull and yank at it until it breaks loose then take the nut out. Question, is all that yanking and pulling safe for the rod that the steering wheel goes and sits into? While I was pulling mine at one point i felt like a little movement if i pull and the same movement if I push back in. It's almost like a click but it didn't break loose. eventually carried on yanking it and it broke loose. Just wondering what the other movement was? It was very very slight if i pull hard it would like click and then if i push in hard it would click again
OldSurfer
RX - 1st Gen (1999-2003)
49
03-04-21 09:56 PM
