HELP Smoke After Valve Cover Gasket Job - '07 IS250
Half each side:
4x 11159-31010 (technically, 2x 11159G-31010, 2x 11159F-31010) but it shouldn't matter
2x 90430-10024
What color smoke do you see? The only thing I can see now. Is a cracked manifold. Do you hear any ticking noise coming from that area? The stock manifolds are pretty robust. Not really sure how it would of cracked. I can't remember the torque specs for the nuts.
If you took off your bottom plastic cover for your transmission, there is actually two 10mm bolts you can custom fit a steel bracket to go across so it can support the weight of the midpipes without it pulling on the headers if you go over bumps or big drops. that's how they crack, like on the ISF as well.
The entire exhaust system on the 2IS (not sure 3IS, haven't gone under to look) is super dodgy how it is attached to the car, one would not expect the weight of the system to be at the forefront so that the headers/manifold have to bear everything. For example, you would expect a pretty robust bracket system for the midpipes since when you go over bumps and anything up down, it will push and pull on the headers if there was none since they attached themselves to the headers. That's how they crack.
#2 Exhaust Support
The smoke is white/grey-ish. Smells like something is burning but it could be an exhaust leak. Would a cracked manifold cause that type of smoke/smell?
Almost certain it is not the valve cover gaskets, there are no leaks visible after degreasing the engine and wiping the entire perimeter of the VC interface.
I don't hear any ticking out of the ordinary but I can listen more carefully next time I fire her. I still have to check the top exhaust manifold bolts to see if they're loose. Will report back.
The header top bolts are tight. But the CEL came back on. Must be the cam sensor. Looks like an easy swap without taking anything apart. But that sucker is $150.
Which cam code is it? A, or B? Do you think the wiring got damaged? The only thing I could think of now. Is the coolant block drain plug bolt is near. The first nut on the lower stud of the manifold. Could it be it's slightly loose squirting coolant on the manifold? Is the burning sweet smelling?
Other than that I can't think of any other fluids source in that area.
Okay I got the replacement sensor. Now just to figure out which one is Position "A" Bank 2. I'm no expert (clearly) so I think there's 4 total, one for intake and one for exhaust for each side. I've been able to locate the four on the diagram below:
Any idea which one is Position "A" Bank 2? I am guessing the one I numbered 4 on the diagram. I guess worst case scenario I could swap it out one-on-one until (hopefully) the CEL clears.
The "A" location are for intake camshaft sensors.
they are located at the front of the valve covers. For corresponding banks 1, and 2.
The "B" location are for exhaust camshaft sensors. They're located in the middle portion of the valve covers.
Disregard the diagram. Highlighted in red are the exhaust sensors. I couldn't find a blank diagram.
