HELP Smoke After Valve Cover Gasket Job - '07 IS250
#47
See link for OCV locations on valve covers.
https://www.clublexus.com/forums/is-...ft-sensor.html
#48
Cross reference the OCV for position A or diagrams as #1. See if they're the same part number for both banks. I'd swap them out and see if the code changes to the other bank.
#49
OCV Exhaust # 153400P020
It looks like both sides are interchangeable. Left , and right.
RockAuto also shows the same.
#50
Copy. So I'll try swapping the intake OCVs and see if the code changes to Bank 1. From the 3D diagram in your other thread ("Bank 2 cam shaft sensor") it is kind of hard to tell which sensor is the intake one on Bank 1. Before I complete the swap, can you confirm (I showed the swap below):
#51
Remember to reset ECU. Otherwise the same code could be shown.
#53
Finally got around to troubleshooting. So I took out the intake OCV on Bank 2 so I could swap it over to Bank 1, and there was a clear blockage in the oil passages. Little metal shavings blocking the flow of oil. I thought I had found the issue! I cleared out the metal shavings, put it back in the original Bank 2, cleared the ECU. CEL returned. Dang. So I swapped the intake OCV between Bank 1 and Bank 2 as advised, cleared the ECU, and the DTC jumped to Bank 1. From P0022 to P0012. Woohoo! The OCV must have been damaged beyond repair. I plan to replace it with a new OCV tomorrow and will report back.
#54
Swapped out the bad intake OCV, cleared the ECU, and no CEL as of yet. It's been about 50 miles of mixed city/hwy driving and the CEL has been typically been popping back up around 10-12 miles. I'm calling this one resolved! Thank you CL for the outstanding help, especially MikeFig82, 2013FSport, and Dealarr. Your patience and expertise saved me a ton of money and time. I appreciate you guys!
Just to recap for those that don't want to read this novel:
-Mechanic (mis)diagnosed leaky VC gaskets (smoke)
-Tore down; replaced VC gaskets, plugs, coils, IM upper and lower gaskets, 6x VVT/camshaft gaskets (under VC)
-Reassembled; smoke continued, 3x code (P0022, P0354, P0356)
-Thought I muffed VCG job (not sealed properly)
-Tore back down; reseated gasket with sealant
-Reassembled; smoke continued, same codes
-Checked middle VC bolts, driverside banjo bolt, coolant drain plug, and exhaust manifold top bolts for any signs of looseness/leakage/oil; none
-Washed down with degreaser; smoke continued
-Swapped out intake camshaft position sensor on Bank 2; smoke cleared, codes P0354/P0356 cleared; P0022 remained
-Swapped intake OCV from Bank 2 to Bank 1; code changed from P0022 to P0021
-Swapped out bad intake OCV
-Golden
Thanks again CL. Looks like my initial problem was probably just the intake OCV and camshaft position sensor, but I got new VC gaskets, plugs, and coils out of the deal! LOL. Black Beauty should be good for a while now.
Next job: 4x pads + rotors. I'm experiencing slight shaking/vibration when braking, especially at high speeds. Think it's a warped rotor. But I'm going to wait a few months, I need a break, heh.
-Golden
Rep115i
04-03-20 10:44 AM
