Help! High beams work lo beams dont
Hey guys first post,
Recently I went to a mechanic and they reset my codes. Whilst I was driving home my high beams came on instead of my lo beams although I was on the auto setting. Normally the lo beams came on-so I was a bit confused. I switched to the lo beams and the lights didn’t come on. When I got back home I checked and saw that the DRL’s were still working both of the blinkers and the high beams all worked well. The only issue is that the low beams won’t turn on no matter what setting I’m on. My car has VLand aftermarket headlights and they worked completely fine the night before I went to the mechanic. I’m thinking when they reset my codes it tweaked with the headlights somehow. Remember the lo beams stopped working at the same time so I don’t think it’s a dull bulb.
2006 Is250
2006 Is250
2006 Is250
2006 Is250
Not knowing what was done during lighting install, I would start with the usual suspects and pull fuses looking for a blown one. Are these HID lights? A bad ballast could pop a fuse, so start there and let us know.
Alright im going to check the ballast I'm just confused cause they went out at the same time so I was thinking it could've been a computer problem. I checked both of the fuse boxes not sure which one controls the low beams.
Alright little update. I turned on the car today and the low beams worked. However they only worked in the Highbeam setting, so now the high beams don't work. Ill try driving around in auto for awhile and see what happens,
