Alternator?? Battery?? Camshaft position sensor???
Hey guys a couple days ago I was getting ready for work I went outside, was about 42 degrees out I started my car to warm it up and ready. I came out about 15 minutes later and the car was off, I saw the dashboard lights blinking and I heard a distinct beeping sound, I hooked up the obd2 scanner because it was marking a check engine light it said code p0430 I believe is the code(camshaft position sensor) and it marked 3 of those codes, I tried to start it up but it wouldn’t start or even crank. I took my battery to a shop they checked it and said it wasn’t good sits at 11.8volts went over 13 bolts when charged but it would drop back down to 11.8V. I had a buddy come over and long story short he hooked up the battery wrong positive to negative and negative to positive caused a spark and I’m not sure if that could’ve blown the obd2 fuse because my scanner won’t turn on any more after that.(Also need help finding the fuse for that). I put in one of my other cars battery in to see if it was just the battery, and the car still wouldn’t start just made a faint ‘Zzzz’ sound. Well that’s for that story I have some background as well, a couple days prior to the incident I noticed that whenever my car would start it felt like it was going to turn off and I got a code p1241 at some point before but it went away shortly after. Sorry for the essay guys I seriously need to figure this out. Thank y’all in advance for the help
