Camshaft sensors bad All 4
Hello
So this morning I connected my Bluedriver dongle as I usually do monthly to check codes for my 07 IS350 and I got a lot of codes
I cleared all codes and started my day. Two hours later I re-checked the codes and these popped up again.
I believe that the MAF code and intake Temp have to do you with the engine air filter which I couldn't replace last oil change because there wasnt any available when I changed the oil.
But I'm more interested in the crankshaft sensors. Apparently all 4 or them aren't working. Car feels and drives fine but I don't know what the sensors do.
Should I replace all 4 of them or is there any other way to check if it's something else.?
Thanks!
Thanks!
Armadous1 (04-20-21)
LOL sometimes I think ignorance is bliss! I recently bought an OBDLink LX and I mostly use it to check my fuel trims, engine temp etc. I'm going to just to run the diagnostics if I throw a code. Out of sight, out of mind as they say
Also no freeze frame data since there are no sash lights.
No changes since last oil change (2 weeks ago) didn't check then. I have an alarm monthly to check oil level, brake fluid, coolant level, check brakes and check for codes. Last month it was fine but now these codes popped up. No changes to the car. Maybe a fuse or something went bad?
I unplugged it and replugged it and no changes..
No rodent issue that I know of...
You would pull it out to clean it
