is250 - tune-up
is250 - tune-up
Hi,
I have a 10' is250 with 105k miles. Besides oil change and air filter, I have not done anything else to the car. It seems to run well minus a PO303 code which didn't come back after a reset.
What are the recommendations for plugs? I'm thinking that I should also clean the throttle body and MAF. Any other suggestions?
Thanks in advance
Thanks in advance
Air Filter
Clean charcoal filter
Clean MAF - CRC Maf cleaner
Clean throttle body
New PCV valve
Spark plugs 60k intervals
Inspect serpentine belt
Idler pulleys
Power Steering Fluid (Joking)
Replace old brake fluid/bleeding
Reset ECU
All these DIY can be found using the search function here on CL, or Google.
Clean throttle body
New PCV valve
Idler pulleys
Reset ECU
Air Filter
Clean throttle body
New PCV valve
Idler pulleys
Reset ECU
Clean throttle body
New PCV valve
Idler pulleys
Reset ECU
******never mind, I found the answer*******
