Turn signal problem help!
Turn signal stays on on dash and goes super fast when headlights are on but when they aren’t on it blinks normally. Also my high beams are always on but super dim
Super Moderator
You didn't mention which model year car you have, neither in your post nor in your profile. You also didn't say whether you have the stock halogen headlights, stock HID, or an aftermarket setup.
Assuming that it's an older IS, it is normal for the high beams to be on at low brightness, as these function as the daytime running lights.
GrizzlyMan (06-09-21)
Doing a walk about with either the 4 way flashers on or left then right directional signals may show a dead bulb. All 2IS OEM indicators are incandescent. When the filament burns open, the relay has less load and blinks faster.
It can also blink faster if replaced by an LED that didn't include a resistive load. Aka resistor.
So if all four cofours blink, study each a notice from full brightness to off if it fades or just shuts off instantly. If the later, you need a digital relay for your turn indicates.
Carson250 (06-09-21)
Swap the bulbs from side to side. Do not leave a greasy finger smudge on the bulb or it will break the glass and murder the bulb. Report back. At a minimum, you likely need new bulbs as D4S bulbs don't live 10 years like the old D2S bulbs did.
I'm running the OSRAM CBI which are about $120 on sale. Worth every penny compared to cheaper bulbs as they really push the light down the road.
Worst case is you need new ballasts. One step at a time....
That said, for this to happen, there must be a separate path for system grounds in the headlight..
Do both sides do exactly the same thing? Please give some details.
Hmmm..... Going back to this. I think my previous post is in error as it seems you lost the ground to your headlight and it's using the High Beam bulb as a path to ground..
Mine did nearly the same thing. It would light cold but when hot fade to orange, flicker and then shut off.
Carson250 (06-11-21)
My driver side headlight Ballast was corroded when I first bought the car and I replaced the whole assembly with new ballast. So I hope that is not the problem agian... even when the ballast was bad only the headlight was having issues, it did not mess with the high beams and turn signal. Also the left turn signal is stuck on my dash when I turn my lights on as well, very weird🤔
I'd guess nothing would work on the bad side if the high beams are turned on.
So, did you fix it? If so, what connection failed?
