How Do You Turnoff the TPMS Light?
Old 06-25-21 | 01:46 PM
4jmp's Avatar
4jmp
Default How Do You Turnoff the TPMS Light?
I have a TPMS check system indication. How do you turn it off? Do I need to reset it after changing the car battery?
Old 06-26-21 | 09:45 AM
DennisMik's Avatar
DennisMik
The TPMS system monitors the air pressure in your tires. If the air pressure drops more than 5 psi in one of the tires, the light comes on. So the first thing is to check all the tires for correct air pressure. If you do have a tire that is low on air and you fill it, the TPMS light in the dash will not go off right away. You have to drive the car a mile or two.
If all the tires have their correct air pressure, then you probably have one (or more) of the pressure sensors with a low or dead battery. The pressure sensors are inside the tire. the stem where you put in air is part of the sensor. If the battery is totally dead, the TPMS light in the dash should flash for a half minute or so when you first start the car.
The following 3 users liked this post by DennisMik:
4jmp (06-26-21), 82ndABN (06-30-21), cfauvel (06-28-21)
Old 06-26-21 | 11:45 AM
Bichon's Avatar
Bichon
Super Moderator
No, the "CHECK SYSTEM" indication is not low tire pressure. Most likely one of the TPMS sensors in the wheels. These have a lithium battery that lasts about 10 years. His '08, if he's still running the original sensors, has 13 year old batteries that have been living on borrowed time.
4jmp (06-27-21)
Old 06-27-21 | 07:14 PM
ELexis's Avatar
ELexis
May have to initialize the tire pressure system after inflating tire to recommended pressure (PSI). I believe Discount Tire has scanner to to perform a reset of the initialization does not work. It may be the sensor as Bichon stated if the mentioned procedures fail to turn off the TPS light;
Old 06-28-21 | 08:57 AM
MikeFig82's Avatar
MikeFig82
Discount Tire will check for free. They should also have the capability to program as well. If you find there is one dead, or last leg battery wise. RockAuto.com has the Denso for cheap. Maybe buy all 4 new sensors. Then get Discount Tire to install.
Old 06-30-21 | 10:19 AM
82ndABN's Avatar
82ndABN
TPMS are an unfortunate outcome from the Ford / Firestone blowout . . .
https://www.townfairtire.com/blog/wh...ntroversy.html
If they are original equipment - and one is suffering a dead battery - pony up the dough to replace all 4 . . .or is it 5 - I forget ifour spare runs a sensor? Probably does - plan for 5 $$$$$
Old 06-30-21 | 12:02 PM
Bichon's Avatar
Bichon
Super Moderator
It doesn't, he only needs four to replace the entire set.
Old 06-30-21 | 10:21 PM
DennisMik's Avatar
DennisMik
The spare tire on the RX is a full size tire and it does have a TPMS sensor in it.
Old 07-01-21 | 11:34 AM
timmy0tool's Avatar
timmy0tool
2nd gen IS cars only need 4 sensors. the spare does not have/need it.
Old 11-03-21 | 05:38 AM
ELexis's Avatar
ELexis
In error, held in the INFO / On / Off button for over three seconds, and now the LOW TIRE message is displayed with the RED triangle icon (no Low Tire icon shown). Perhaps the button was set to Initial tire setting in error when button was held in too long. Does vehicle just need to be driven a while to have it return to normal?
Old 11-06-21 | 06:37 AM
ELexis's Avatar
ELexis
Low Tire and Red warning icons have since gone off after driving vehicle.
Old 12-18-22 | 08:39 AM
JunoBR's Avatar
JunoBR
Hi Mike,
I have an appointment with Discount Tires next week and 4 brand new Denso sensors. Can they do the full reprogramming? I have been reading about it and it appears as though it's not that easy of a job, requiring Toyota Techstream software. Thanks.
Old 12-18-22 | 09:17 AM
ELexis's Avatar
ELexis
I thought it was possible to just change the battery in the sensor however, believe the sensor is sealed and battery is not accusable, and changing the sensor due to low battery is needed (OEM part 4260733022 (DENSO 5500103) - Tire Pressure Monitoring Sensor
How to replace & register TMPS tire pressure monitoring system sensors on Toyota, Lexus, Scion cars video;
Old 12-18-22 | 10:33 AM
JunoBR's Avatar
JunoBR
[QUOTE=ELexis;11412393]I thought it was possible to just change the battery in the sensor however, believe the sensor is sealed and battery is not accusable, and changing the sensor due to low battery is needed (OEM part 4260733022 (DENSO 5500103) - Tire Pressure Monitoring Sensor
[QUOTE]
Thank you for that information. I bought all the new sensors. I’m just wondering if Discount Tire is going to be able to install them and reset the system and all of my lights on the dash. They have already agreed to use the sensors I bring in which is great.
Old 12-19-22 | 08:22 AM
Bichon's Avatar
Bichon
Super Moderator
They should be able to scan the serial numbers of your new sensors into their TPMS tool, then plug their tool into the OBD2 port to record the new sensor numbers into the TPMS controller in your car.
(Which is a difference procedure than those shops that require you to buy their generic sensors use; where they instead scan the serial numbers of your old sensors into their tool, and then clone those original numbers into generic TPMS sensors, eliminating the need to re-program new codes into the car)
