I have an automatic 2007 Lexus IS 250 with 154K miles on it, today when I was parking my car and with the car already in reverse when I went to switch the car into drive the car just stalls on me, check engine and battery icon comes on, radio and ac are still on but the car won't move. I then shift it back into park and turn off the car and start it up again. When I shift into drive from park it's fine but when I go from park -> drive -> reverse -> back to drive it stalls, I make sure the car is at a complete stop when I do this. I then turned off the car again and wait like 30 mins and when I start the car up and shift it between the gears the car is completely fine, no stalling at all. This occurred back in February and I did a basic tune-up and cleaned the throttle body and it hasn't happened again till today. Normally, my car sits at 600-700 rpm at a complete stop if anyone can give any suggestions on what causes this, please let me know!
Hello JulieH0719, To confirm, when your changing settings (from Park to Drive, and Drive to Reverse etc.), you are holding the brake until the transmission engages in the selected position, and not rolling into Reverse from Drive, correct?
I believe when transmission shifts into reverse and brake is engaged, it’s creating a load against the transmission and the engine. If the engine stalls, possibly defective idle control valve, O2 sensor or bad fuel injector??
So are you scanning for codes when the light is on? Then you see no codes present? What scan tool are you using?
I’m not scanning the codes cause when the car stalls on me like that it basically turns the car to the key on mode. You know like when you push the start bottom without your leg on the brake, it doesn’t start the car but like the radio turns on. What’s happening to me is when I’m in reverse and right when I shift the gear to drive I can hear the engine shut off, basically switching the ignition to the key on mode
Ok I see now. My first guess would be then a bad neutral safety switch. It has the symptoms.
If the car starts only in park, and neutral. Then most likely is the switch. Can you have someone view if the reverse lights activate once in reverse?
If the car starts only in park, and neutral. Then most likely is the switch. Can you have someone view if the reverse lights activate once in reverse?[/QUOTE]
Originally Posted by JulieH0719
my reverse lights do activate in reverse.
First I want to correct my quote. If the car starts in park,, and neutral then most likely it ain't the switch. Sometimes it will start though if bad too. If the car starts in any gear then yup its bad.
Have you did a run down on checking the intake tube from air filter to throttle body? Now I'm thinking a loose, or disconnected vacuum air hose. Possibly maybe even torn,split. So when you shift into gear the engine moves, and unmetered air kills the engine. That's my only thoughts. As like I mentioned before the ECU will store some codes. Other than that we are all chasing our tails on the subject.
Understood, thanks for following up. Vehicle still continuing to stall when shifted from Reverse to Drive?
Also, what is the model / manufacturer of OBD II scan tool you using (BOSCH 1350 etc.)?
The car hasn’t stalled at shifting anymore since it happened but what occurred about 2 nights ago was I went to start my car and I heard the engine start up but then it stalled right away and went to the key on mode which was weird so I turned off the car and start it up again and it was fine but I noticed the navigation screen say something a long the lines of system restarting and my clock was a completely different time as if some one disconnected the battery. I have the hypertough HT309 OBF2 scanner
That's a new symptom, correct? When vehicle stalled, was the Check Engine ICON displayed and did Engine Start / Stop button show an amber light? Sounds as if power was interrupted or
battery voltage fell below the certain threshold for clock and Navigation screen to reset after starting. May be a separate issue. Have you had battery / charging system checked? AutoZone, Advanced Auto will do for free.
