Driveshaft removal to swap transmission
Ok folks, I followed the tread to remove auto trans, and all was good except getting the drive shaft out of the trans. Can anyone help? It said to remove the bracket and the amount of room to slide it out but no go. How do you remove the center section? I have the bolts removed, but it is totally stuck together. Help please I am so close but feel so far! Thanks
Sorry, not sure if 250s used the same thing but dropping the mid and tail section works both cases.
GL!
marvin5881
03-23-19 01:06 AM
LS400_96
02-28-09 10:19 PM
slappy96
Performance & Maintenance
04-05-08 02:23 PM
