P0300 Random Cylinder Misfire
Hi,
I have lexus is250, it was running excellent without any problems, I stopped it for two days, when I start up the engine yesterday,I notice there is Engine hesitation, I used OBD II tool to scan the code and I found
p0300
p0301
p0306
which means issue in cylinder 1 & 6, the CEL was off but the code has come as pending in the scan tool.
I cleared the code and I drove the car for 2 Km.
today morning, I startup the engine, there is hesitation but less than yesterday. also there is no pending codes.
does anyone can help me
what the problem exactly is?
because it happens only when I stop the car.
p0300
p0301
p0306
Hi,
p0300
p0301
p0306
p0300
p0301
p0306
it's 151000 mile, I thought it's due to carbon build up, what is the best way to remove it?
also, yesterday I drove the car for 90KM and today morning when I start up the engine, it was perfectly without any hesitation. I thing this will help us detect the problem.
I'm sure the problem will come again
https://www.clublexus.com/how-tos/a/...mize-it-367282
cfauvel (07-15-21)
Wouldn't the cold start injector 23260-31020 be washing the backs of the valves a bit, albeit not as well as the IS350's port injectors?
do you think the BG GDI service actually work? or NEEDS to be walnut shell blasted?
https://www.bgprod.com/services/gaso...air-induction/
interesting stuff
As for the BG not sure I have never used it. What I have done is use seafoam to clean the valves. Depending how gumed up the valves are it may take a few cans.
If using the port above the evap line on the intake manifold. By doing this I then removed the lower intake to verify the effectiveness. It seems to hit most of the valves good. It doesn't quite hit the valves on cylinder 6 well. It still had a soot build up on the valves compared to the other 5. The remaining soot stuck on valves I just vacuumed up. They were pretty much spotless after that. If you follow the instructions on the seafoam can to the T you shouldn't have problems. Though I think it's only for a 1/3 down the vac line. Using the whole can won't hurt. Be prepared for a smoke show. So don't do this in a residential area.
cfauvel (07-16-21)
The CS injector only mist a few seconds before start up. literally you would need the injectors to be squirting right behind the valves like the IS350 to be effective.
Surely when doing this , it throws several codes for: o2 too rich, engine misfire etc....right?
cfauvel (07-15-21)
interesting stuff
Walnut blasting is actually really easy to do. Be careful with those intake cleaners. I'm replacing my engine because I used a system made by Berryman. I have used 3m and ATP AT-100 several times in the past without issue. I gave the Berryman stuff a try because it looked like an awesome kit. The directions said to inject the chemical with the engine at idle, wait 30 minutes and then go for a 10 minute drive. When taking the car for the10 minute drive it hydrolocked the motor and broke a connecting rod. The 3m and ATP kits have in their directions to keep the engine at 2k rpm while injecting the chemical which is different from the Berryman that just says to let it idle. Anyway, it flooded the intake manifold. I ended up walnut blasting the intake valves on the replacement motor I picked up. I bought a 20lb media blaster from HF and made a makeshift media wand to get close to the valve. I used coarse walnut shells as the media. While blasting I also had a shop vac going with a crevice tool in the intake to vacuum up the media while blasting and covered the opening of the intake with an old rag so the media didn't get everywhere. It costs me around $120 for everything to do it. I wish I would have just media blasted the valves from the beginning every time I did a spark plug replacement. It's definitely the way to go.
https://www.harborfreight.com/20-lb-...ter-68994.html
https://www.harborfreight.com/25-lbs...dia-92150.html
I used the larger tubing from this air wand with the sprayer that comes with the media blaster: https://www.harborfreight.com/20-in-...gun-68261.html
cfauvel (07-16-21)
I assume you had to remove the upper and lower plenum ...then did the intake ports where the valves were closed, the turned the crank until the next set valves were closed....right?
That royally sucks about the engine.That must have been pretty expensive.
my kid's car is new to us with 104K miles...when should we do this?
The BG service recommends every 15K miles....which is about yearly.
WHY OH WHY didn't Lexus use the same injection system as the 350??!!!
I found this tool, that seems to make the walnut blasting a little easier in that the dust and gunk is not thrown everywhere.
https://www.ebay.com/itm/202732775020
Saw a video where he used a similar tool on a Mini-cooper and the valves ended up like brand new.
Thoughts on a Oil Catch Can to educe the amount of sludge on the valves?
Yes, it is stupid expensive and a waste of a lot of time. I was quoted a minimum of $4,500 for a rebuild and the shop actually recommended I just buy a JDM motor and swap it out which is the direction I am going. The JDM motor was just over $1k but a lot of parts from the old engine need to be reused since the JDM motor doesn't have the starting fuel injector. I'm swapping the engine myself to save some $$ but I am also replacing a lot of parts like the water pump, starter, alternator, AC compressor, a bunch of gaskets etc etc while I am at it. One of my kids is about to get their license so this car will go to them. I ended up buying a GS350 to replace it with for myself with the better 2GR-FKE motor.
With your car being at 104k miles I would probably do it. All of the chemical cleaners I have used have helped somewhat but walnut blasting gets the valves absolutely clean. That adapter you found on ebay would also make the job a little easier and I think it is worth the $30. Spark plugs are suppose to be replaced every 65k miles so you might as well just go ahead an do that too and just walnut blast every time you change plugs.
I also have an oil catch can on my car but most of the oil seems to come from the case breather tube that is attached to the intake line. I get very little oil in the catch can.
cfauvel (07-16-21)
opsta
07-27-06 09:33 PM
