F-Sport Shocks
F-Sport Shocks
Hi everyone I have ran into a little bit of a problem and was wondering if I could get some help. I ordered all F-Sport shocks and springs for my 07 IS350 and they emailed me and said that they couldn’t get the left front shock because it is no longer available. So I thought it’s fine just send me every shock except that one and the springs. So I ordered the shock from another website and they cancelled my order about an hour later saying they couldn’t get it. I am not sure what I will do now. I have everything except the 1 left front shock which is part number PTR13-53094. Any help is appreciated.
@ACLR8 I did a quick search and found a front set of F-Sport shocks available. The only issue is that they're sold as a pair and not individually. I don't know if you're able to return your front passenger shock for a refund or not. If so, you could do that and order the front set of shocks. They're listed for $435.66 on that auction site.
@ACLR8 I was in the same predicament. I couldn't get the 53094, left front shock. Don't bother chasing the unicorn, they discontinued the shock and there are zero showing up in inventory in the country. Waited for 3 months to no avail. I ended up ordering 53080 and 53081 as those are still somewhat available. In the process of installing them this week.
wakaru8 (08-06-21)
Nice! We're twinning! Don't know if you're doing the work yourself or not. I am and I had a hell of a time one nut from the front and one bolt from the rear strut. The rear was rusted and frozen inside the strut. Tried everything.....penetrating oil, hammering, impact wrench, blow torch also to no avail. I loosened it to backed out enough to cut both ends to free the strut. Took me two days! Anyway, good luck!
Hey guys, I just wanted to give an update on the car. I got the 2 new shocks front shocks and then headed straight to the dealer to have it all put on. I’ve had the car for about 2 weeks now with the new shocks and springs put on and I have to say, the car is a totally different person. There is little to no body roll which is great because I can now take turns harder without getting thrown around in my seat. I also had the F-Sport sway bars put on so the combination of the new shocks, springs, and the sway bars made this car handle like a dream. Another thing to add is that the car looks really good because of the lowering springs.
AMIRZA786 (09-03-21)
What PN's went in front and rear??
Snag an IS-F steering ECU and you'll kick up your driving experience a few more notches... several threads and 100's of posts on this topic.
The part numbers are 2x PTR13-53095 for the rear and then PTR13-53080 and PTR13-53081 for the front. Also, I actually do have an IS-F steering ECU already, and that I'm sure also helps with the steering quite a bit.
2013FSport (09-03-21)
The part number for the F-Sport front and rear sway bars isPTR02-53082, and the part number for the lowering springs is PTR07-53090. I am actually currently in college and I don't have the car with me so I can't do the measurements for you. Sorry about that.
stlgrym3
Suspension and Brakes
02-06-11 01:25 PM
