08 is350 is getting $7e8 0r p0390 code
![Red face](https://www.clublexus.com/forums/images/icons/icon11.gif)
my 08 is350 is getting $7e8 0r p0390 code I was driving down the highway when my car begin to lose power and start to slow down i pulled over to the gas station once i stopped it shut off i gave it a minute then started it back up when i put it into gear it shut off again so i managed to drive it slow home not over 40 got the codes tested came back P0390 camshaft position sensor b bank 2 i changed my oil and spark plugs to make sure it was not just a tune up issue and nothing i changed my crankshaft sensor down by the ac compresssor and now my car will crank but not turn over but is still reading the same code can anyone help please?
Worth a shot, remove the battery terminal and after a few minutes hook it up and start it up and see if the CEL disappears. Like re-booting the computer. Good luck. Did you say you already replaced the crankshaft sensor?
it was listed as one of the main possible causes but when sitting in the drivers seat do you mean the sensor that is under the carpet in bank 2 or the sensor wire under the hood i cant find a good diagram to find exactly where it is actually got it to start but it has a loud rocking noise when i accelerate past 3000 rpms then stops once let the gas pedal go
GrizzlyMan (08-17-21)
I suspect a wiring problem more than sensor problem as the sensors are pretty bullet proof.
