Anyone Ever Change Fuel Filter?
I was researching the fuel filter and couldnt find clear info. Does the fuel filter on a IS350 need to be changed? My car has 224K miles. If so is it in tank or under the car outside the tank? Next week the car will be up in the air gettting the preowned cats put in (hope they are good!)and I wanted to do whatever other maintenance I can do.
I saw awhile back it's in tank and they did change it and the gas flow increased from it.
For the most part, Lexus is correct. It doesn't have a stated service interval (though, tbf, neither does the trans fluid and most of us have changed ours), it's really a "it depends" sort of thing. If you're bored, and want peace of mind, and have a high mileage IS, go for it.
Typical signs are fuel starvation under load... They can start and idle fine, but go lean under load - let's just say 3,500 RPM up.
It's a good time to look for water too.
Here you go. I didn't add much pictures since you can find links, and other Lexus model DIY all over CL forums. The concept is the same.
https://www.clublexus.com/forums/is-...el-filter.html
The following 2 users liked this post by MikeFig82:
2013FSport (08-24-21),
Ken167 (08-25-21)
I plan to just change my entire fuel pump in the near future when I had actually solved my VVTI issues being throttle plate on throttle body is loose. Big dip miscalibrated it to a point where it can't be fixed, replacement on the way. There is one on Ebay which is the same as a Delphi one, cost more than twice but is the same model. If you changed the whole thing, it is much easier than removing a lot of connecting clips, annoying as hell. Changing fuel pump = changing pump and filter. Will test how well it lasts.
https://www.ebay.com/itm/39306634690...QAAOSwibFfKMp6
1JZPWRD
Performance & Maintenance
14
11-01-12 04:17 PM
