Figs Front Sway bar bushings. Great Purchase!
Just installed the Figs purple poly front sway bar bushings to eliminate the random thump and rattle noise I was going over bumps. Install is pretty basic. Get the front of the car on jack stands and remove the center plastic splash shield. I would say there about 12 10mm screws and 3 push pins. Once that is out of the way its just 4 14mm bolts that came right out with my 1/2” Dewalt Impact gun. I wasn’t really expecting anything other then getting rid of the clunk but wow did it improve the handling of my IS350. Very linear going through turns and eliminates the sloppy body roll I was feeling in the front. I have these along with the Figs LCA bushings and it really tightens up the front end on the IS. Im right at 78k miles and it rides better then I remember when it was new. Two big thumbs up from me. I bought the 27mm for a 2012 IS350
https://shopfigs.com/v3/CAT-LEXUS-2I..._SW_FR-SP3584K
https://www.clublexus.com/forums/sus...l#&gid=1&pid=1
I had an odd rattle from the front left side that made a sound like if you just casually tossed the jack next to the spare tire in the trunk without securing it. Once I pulled the old bushings off you will see how much larger the hole in the bushing has become over time.
FSporting (08-26-21)
I ended up replacing my front F-Sport Sway bar bushings with ISF Sway bar bushings. The F-Sport bushings were also poly, and when the grease seeped out they began to squeak. Re-greased them and a few months later they began to squeak again. It's been almost a year with the ISF sway bar bushings and so far no noise and handling and feel is very good
AMIRZA786 (08-31-21)
Kajukenbo
Suspension and Brakes
10-29-02 02:50 PM
