Weird issue: No accessory mode but car starts fine
Super weird problem.
The car starts.
I can’t put it in accessory mode, power tilt not working, trunk doesn’t unlock(opens only with key).
if it’s running and I turn it off, literally turns right off skips the radio staying on, the seats going back and the power tilt going back. No dome lights turn on either. The door lights turn on when I open the door.
remote lock not working either.
Stumped. Any ideas? I’m pretty car savvy but this one got me.
The car starts.
The car starts.
The car starts.
What car do you have? Start by getting the battery connections checked and the battery tested.
I don’t recall if the radio stayed on or not but things like courtesy lights and lock/unlock don’t work won’t work. The trunk won’t open with the switch(either way with the glove box button switched)
very very weird.
if you click to start the car it won’t go to accessory mode. Literally only can turn it on they everything works.
2IS. 2009 isf.
very very weird.
very very weird.
Suspects are:
Dome 10A
Security 7.5A
ACC 7.5A
AM2 7.5A
PANEL 7.5A
MPX-B 10A but unlikely as too much collateral damage.
FUEL OPEN 10A also not likely but see if fuel door works.
Start there and pull those fuses for visual inspection.
Data from OM for 350 so it may not map over exactly.
Just wondering....you still have all your doors closed when you turn off the car right?
Also, what happens when the car is off and you press the start button (without your foot on the brake)? Does it go to accessory mode?
if I press it once nothing. I press it again and it’s on “on” mode but not on if it makes sense.
no accessory mode what’s so ever. Car is either on and everything works(dome and all) or shut it off and nothing works. Mind blowing
Super Moderator
What happens if you put the (running) car in neutral (not park), and press the start button one time to turn off the engine. Then you can shift to park.
That's how I put my car in accessory mode when I just want to sit and listen to the audio system at the end of a drive.
off to check the fuses mentioned above.
Sounds like a fuse popped. Time to go on a mission.
Suspects are:
Dome 10A
Security 7.5A
ACC 7.5A
AM2 7.5A
PANEL 7.5A
Suspects are:
Dome 10A
Security 7.5A
ACC 7.5A
AM2 7.5A
PANEL 7.5A
gas tank was always working so good there.
trunk doesn’t open, remote or button on handle doesn’t lock the door. Steering wheel and seat settings still don’t function(like auto when you turn on/off the car) I can adjust seats. Can not adjust steering wheel. Trunk button on car and remote don’t work must open trunk with key.
progress in right direction!
now one thing I just thought about. I did send out my black screened nav unit and threw in an 08 unit for the mean time. Everything plugged in but the clock plug(so no time and airbag light) so airbag light is on but I know why.
could the plug not plugged in have something to do with all the stuff that doesn’t work? Maybe something to do with the security functions?
Quick update. Depinned an 2010 radio clock plugged that I bought when I first went to fix the black screen(found out the expensive way there were 2 types) lol. Made the clock and air bag lights work so everything is plugged and has a home so I know it’s not the radio.
What’s left to figure out is the trunk no opening and steering/seat auto setup(not even power adjust works when the car is on) and the door locking part. Deff a fuse I’m missing some where.
Ok so another update. Seems like I’m the middle of pulling all the fuses I must of put back the telephonic fuse in the empty space next to it. Plugged it boom it’s back.
trunk button was unpushed so I guess when I changed the MPX that brought back the trunk.
Everything is back in action! Thank you to all that helped and I made sure to come back and document it all for the next person incase they run into this issue.
something tells me that plug for the clock/radio/airbag light has something to do with the security system for sure.
Glad you have it all sorted...
