Alternator question
Alternator question
Hello, i am in the process of replacing my alternator. I bought a used oem alternator and is missing a stud. The stud did not connect to anything. should i swap the old stud onto the replacement alternator.
The stud is on the upper left corner.
Looking at pics of a new alternator it comes with the stud and a nut as well. Is something else missing that it is supposed to bolt to it? I guess you could swap it so junk doesn't built up in the bore. ...wait I think that might be a ground but don't connector the power lead to it!!!!!!
alternator change
regarding the alternator on the 2008 rx350....are there only two bolts holding it on [screwed in from the outside of the engine towards the center], or is there a third one that must be accessed with a lot of trouble and which screws in from the center of the engine towards the outside? it's hard for me to describe it better than that. two bolts or three?
