Rear Axle camber issues
Old 12-21-21, 06:41 PM
dkdillan
dkdillan's Avatar
Default Rear Axle camber issues
So im trying to run Extreme camber on my is and i ran into this issue with my axle being shoved in as in the picture. Has anybody ran alot of negative camber on a is before? Not sure how to do it if my axles cant handle it.
Old 12-22-21, 08:44 AM
2013FSport
2013FSport's Avatar
Received 1,531 Likes on 1,274 Posts
You talking about the boot being scrunched up?
Old 12-22-21, 09:19 AM
dkdillan
dkdillan's Avatar
yes the axle boot
Old 12-22-21, 11:30 AM
2013FSport
2013FSport's Avatar
As body goes down, the wheel goes up and this gets better. How low is it and what kind of camber does it have?
You might try w a new band clamp and cut the inner boot clamp, slide it a bit and see if it helps. Apply new clamp when done.
FWIW I take zero responsibility for anything that happens if that option is used.
Old 12-22-21, 01:56 PM
timmy0tool
timmy0tool's Avatar
well running anything extreme will cause issues with other things too, like tire wear but you've made your bed.
in my opinion the axle looks fine, just the boot is pushed in more and will eventually wear out. is anything binding? any noise heard from the driver's seat?
bayawak69
Suspension and Brakes
15
08-06-15 05:47 AM
Spamboi
06-18-15 08:39 AM
EffSport
23
02-13-15 08:41 PM
Sheehan1p
09-05-12 03:57 PM
tn96dc
10-29-11 11:06 AM
Quick Reply: Rear Axle camber issues
