Leak?
Leak?
Can anyone tell me what is causing this to happen? Also the motor sounds like it has the cam issues other is 350s suffer from but it had the recall done years ago so it doesn’t make sense. Could it be the oil? I use Mobil 1 full-sys 5w-30
Normal oil seepage. Use some simple green, wash it off and then monitor. If it were wet, that will be an active leak.
