Rapid rattling noise on start up from Infotainment Center?
probably cd is stuck, shine a light at the cd slot and look in it
Sounds like the disc drive mechanism is sticking on the head unit.
Are you able to insert a disc, and eject?
I'd say if any of the lubricant has gotten dry over the years. Im assuming it has some sort of grease like the AC servos.
This morning, it didn’t even do the rattling upon start up. So will check out disc port this weekend and keep an eye on it.
@MikeFig82 Shop inspected the CD player and said it was jammed. They recommended replacing the head unit. I finally got a CD to try on my own & it kind of got stuck... it would come out about half way & go back in right away, so I just had to grab it quickly before it was dragged back in. Is the ticking upon start up, the CD mechanisms and its just now gotten old and stuck? Should I attempt to remove head unit & clean up the disc drive mechanism & apply more of that grease AC Servos you mentioned?
Though in my quest to find some seat rail grease. I came across this stuff. It seems to be for plastic on plastic, plastic to metal. I wouldn't recommend white lithium. It's probably will be too runny, and high odor. Not sure how much odor on the PG-75.
JediKeith
CT 200h Model (2011-2017)
08-25-14 07:58 AM
