Help with offset please
Hi There,
We have a stock 2008 Lexus IS 350. We are getting new rims. We are doing 18 x 8.5 in the front and 18 x 9.5 rear. Today we found out the rims we really want are +38offset not +35. Will this be an issue? I really don't understand offset. We are not interested in lowering or rolling fenders and we do not want rubbing. Help please
Hi There,
To understand how offset (ET) works use this website.
https://www.willtheyfit.com/
isaacrvl88 (03-12-22)
+35/+38 8.5/9.5 but in 19”. Flush , light rubbing but I’m lowered. Your specs will be fine.
18x 8.5 +37 and 9.5 +38 no issues at all 235/40 and 275/35 tires
L350XIS (08-28-22)
Hi.
Do you think 275/35 might work on 9.5 wide wheel with an offset of +35 if I do fender roll?
I love the look of your car with that wide tire in the rear and want to do the same. I don't mind rolling fenders if I have to just want that 275/35 in there at all costs.
Any advice would be much appreciated. Also I'm on H&R lowering springs
I run 265/35 on a 9.5 rear wheel setup for my IS350 and had the fenders shaved off from the inside. I decided on this method against fender rolling because cutting looks and provides a much better clearance. You could not tell even when looking at it directly.
