Rear Axle Knuckle Bushing
For the past month, I have had a very annoying squeaking sound coming from the rear of my car. Eventually, after several mechanics and money spent on parts, we found out that the issue was the rear knuckle bushing. After reading many posts regarding this issue, I found this DIY (https://www.clublexus.com/forums/sus...placement.html) however, it is mainly for the GS and not the IS250-IS350. I want to buy the bushing but all of the posts so far do not indicate if the bushings for the GS would fit the IS250 since I cannot find the bushing for the IS. My other alternative would be to buy the entire wheel hub assembly which can be more costly. If you have the aftermarket part number please share it with me. Thanks!
Is this it? I know in Australia but maybe will lead you in the right direction
https://www.ebay.com/itm/283680650924
So, according to this, if you buy a new spindle it comes with all the bushings / spherical bearing in it??
Toyota used these bearings in a lot of vehicles. I sure wish we knew the exact size. Most suppliers sell greased, sealed, spherical bearings for <$25 each...
https://jp-carparts.com/lexus/partli...ype=9&fig=4102
NSK, SKF, Timken, rbcbearings, MOOG
https://duckduckgo.com/?q=sealed+sph...bearing&ia=web
https://www.schaeffler.com/remotemed..._218_de_en.pdf
FWIW: I wrote moog to see if they have a direct application.
Edit: these PN's come up as possible / maybe?
42210-14010 BUSH ASSY, LWR BALL
42210-20010 BUSH ASSY, LWR BALL
