AC controls question! Help!
Is there a way so the AC starts on Ventilation instead of Recirculating mode? I have to click the button each time I start the car in order to switch mode,.
I will check if mine does this. But as far as I remember, It will save the last setting as you turn off the car and then it will go back to recirculation depending on the current cabin temperature. I noticed that mine starts on the ventilation, then as soon as I started driving for a couple of miles, it goes to recirculation so it must be the auto climate sensing.
I think there should be a way to change the settings using Techstream.
65beto (05-31-22)
But ya, it might just go to recirc depending on indoor/outdoor temperatures. "It thinks it knows the best way to cool/heat the car but is clueless as to the window(s) position and can default to stupid.
65beto (05-31-22)
Protholl (06-05-22)
