Does the navigation screen fade with age? (Can't see screen w/ convertible Top down)
This summer I got an 2010 IS350c with the factory navigation.
The screen looks OK at times, but when I put the top down, the sun... or sometimes even just the normal daylight -- washes out the image
so that I can't see or read anything on the screen.
Do the screens fade with age, or were they like that on day one.
I ask, because I found a company that makes and sells a replacement screen with digitizer for the car. It costs $300, and I can install it myself, but
I don't want to bother if the screen brightness is normal, and it'll still be unreadable with the top down.
I wonder if their are any higher quality screens we can put in (obviously they would have to be compatible with the ribbon-pin connector, but it sure would be nice)... and of course we could
put a tanin digitizer on top of the better display. (Just wondering).
@Zmon did you replace your LCD too, or just the digitizer?
I've also read some posts where people has stated that an anti-glare screen helps as well.
-Phil
Hehe! I like that!
I saw there was a TSB for some 2010 (and a few other year) screens where the digitizer wears and scratches... the TSB allowed for a replacment.
In looking at my screen, it's well worn. I'm starting to think that the unevenness of the scratches may diffract and diffuse the light, making it hard to read when the top is down. I'll do more reading, but maybe I'll try replacing ONLY the digitizer... and keeping my screen... and putting a protective film over the new digitizer.
That alone might brighten up the display and make huge difference, especially if I find an anti-glare film to go over it.
is350c2010 (09-04-23)
Yes, Tanin is the brand that I was considering getting... both the digitizer and a new LCD... but only because I can't read my screen in the daylight.
-Phil
-Phil
If you buy the LCD/digitizer, it will be much easier to do at least as you don't have to separate the old digitizer from the LCD like I had to do.
Update: I've decided to go with one the Android radio replacement units. I'll use the one that comes with a frame around the display (similar in style to OEM... but not identical) and include a canbus module so that the A/C controls still work.
I see that there are different models and configurations, so I'll contact one of the sellers to make sure that I get a compatible unit.
I'm also replacing the factory amp with an aftermarket amp... so I'm hoping that this will cause fewer compatibility issues... but I guess I'll speak with the vendor about those issues.
Anyway, the android radios run from between $200 to $500, and they include a modern, bright, vivid display. I"m also only looking at units that support wireless carplay... which will be nice!
