Do the OEM brakes still squeal?
Need to do a brake job in the front and am currently contemplating whether I should still go OEM or not. Currently running a fully OEM brake setup all around and they squeal like crazy regardless of temperature/weather. The brakes were put on back in 2017, so I was wondering if the issue has been fixed since then (since I’ve heard something about a TSB floating out there). Here are the part numbers I’m planning on picking up:
43512-22261
43516-22011
Front Rotors
04465-30500
Front Pad Set
04945-30350
Front Shims Set
43512-22261
43516-22011
Front Rotors
04465-30500
Front Pad Set
04945-30350
Front Shims Set
OE is fine but they dust so much, and yes they are noisier as well. they do perform very well however; marginally better than akebono from my experience.
i still prefer akebono (run them on all my cars/trucks) just for the fact it dusts so much less but they don't have that same initial bite that OE pads do!
Yeah I've seen people mention those on the forums, would you happen to know any part numbers?
+1 for Centric Rotors and Akebono Ceramic Pads. It's been working great for a year no noise, no issues, good braking, low dust, cheaper than oem
I bought from RockAuto and Amazon
https://akebonobrakes.mypartfinder.com/
https://centricparts.com/product/cen...s/rotors-drums
FatherTo1
01-29-18 11:01 AM
