2006 IS250 Won't start
1st Gear
I have a 2006 IS 250 AWD and recently couldn't start the car. Thought it was the auto disabler after trying to jump the car; AAA was able to start and used for a few days then wouldn't start. Read codes P0335, P0340, P0345, P0365 and P0390. Car battery was checked and found to be bad; replaced the battery, still won't start. Noise when attempting to start is a mechanical whirring like the starter solenoid is spinning but won't engage. Wanted to rule out a camshaft position sensor failure but both going bad at same time seems odd. Tried to rule out bad sensor, but couldn't read any voltage on connector to sensor on either one, which is weird. Any thoughts? Probably a starter but was really curious why I am not reading any voltage at connection to position sensor with car switched on to ACC.
ecassaro19
05-15-18 01:22 PM
