door locks
door locks
hi, I have a 2007 IS250 from a friend here and the doors aren't locking only unlocking.
We tried already replacing the battery of the remote controls
- Resetting the car by leaving the car battery overnight off
- tried to replace fuses
- measured all fuses and they are all right.
Where the .... is the fuse of the central locking system or is there something else going on?
Do ALL the locks lock when you use the button on the driver's door panel? If not, you need to replace the BCM.
If the locks work properly with the driver's door panel button, you probably have key fob with a bad circuit board and it needs to be replaced & programmed to the car.
To test the key fob, go to any retail auto parts store and test it with their test thing.
enshiu (12-28-22)
I have resetted the right foot well BCM by unplugging the + and - on it for 30mins and after installing everything works again.
Protholl (12-28-22)
Weird thing is it doesnt work anymore suddenly . I guess battery issue ?
no fuses are giving the problems, I have replaced all fuses and bcm and problem gone.
crwiseman
GS F (2016-present)
14
02-03-23 06:34 PM
rgc
ES - 5th Gen (2007-2012)
08-31-18 06:09 PM
