07 IS350 Headlight not working
Hi all,
my passenger side headlight completed stopped working as it doesn't not even flicker when I switch my headlights on. I had inspected the bulb itself and tested it on my left side and it worked so I know the bulb isnt the issue as I had swapped it less than 3 months ago.
I had read a couple forums that it would possibly be the Ballast needing to be replace but I would like to hear from your guy's experience on what other components might be the issue. Could it be tripped wire even?
For further reference, the passenger side DLR and Fog light work with no issues. It is just the headlamp that's not getting any power. I lost my passenger side fender liner under a snow bed so im not sure if being exposed to the snow would damaged the wiring? Id imagine the DLR and fog light would of been affected too if that were the case.
Thank you all for your Input!
Mariozechu
02-12-18 11:11 AM
