2018 Lexus IS 300 Grill Swap
1st Gear
Hello all,
I have a 2018 Lexus IS 300 base model and need some help to see if I can swap my base grill for a f sport grill? I've read a lot of threads on this but does anyone know how the process is like and what exact parts I need? Also, what is the wiring process with the sensors and all like if I do proceed to do it? It is as simple as it seems or does it require a lot of work? Any help is appreciated! Thank you!!
It’s a direct swap the brake ducts will need to be changed to work for the Fsport grill but everything else should just mount back up to between the two. If you are wanting the full Fsport look, you will have to swap the whole bumper as the faux side grilles are slotted and tabbed into place.
All the info is here:
https://www.clublexus.com/forums/is-...f-sport-2.html
I did the swap, and I'm getting a body shop to make the slots on my current bumper to fit the side grilles.
You don't need to swap your bumper (save your money).
